It is currently Mon Jul 28, 2025 2:32 pm
 Post subject: glue flex
PostPosted: Sat Oct 31, 2020 3:02 pm
I guess empirically, glue must be flexing, or else the top braces would pop off when the bridge twists. But, there is often reference to hide glue and fish glue drying absolutely hard and will not creep. So, how much can glue joints on the top flex before they are compromised due to the glue cracking?
 Post subject: Re: glue flex
PostPosted: Sat Oct 31, 2020 3:10 pm
The ideal glue joint is one molecule thick. So the glue provides no resistance to flexing. That all comes from the wood.
These users thanked the author Barry Daniels for the post: wbergman (Sat Oct 31, 2020 7:38 pm)
PostPosted: Sat Oct 31, 2020 4:14 pm
First name: Hans
Last Name: Mattes
City: Petaluma
Zip/Postal Code: 94952
If we could get wood surfaces so well-matched that a "one molecule" glue line was possible, we probably wouldn't need glue at all -- we could just rely on a wood-to-wood bond. In the real world, wood surfaces are not so smooth.
Studies (e.g., http://www.franklinadhesivesandpolymers ... f?sfvrsn=0) suggest that the most effective spacing for wood-wood gluing os 0.002" to 0.006". That's quite demanding and is why significant clamping is necessary to distort the wood surfaces into such intimacy. (That's on the order of 5,000 to 15,000 glue molecules thick -- for molecules of a typical glue.)
All that said, Barry is absolutely right, the flexing comes from the wood.
These users thanked the author Hans Mattes for the post (total 2): Skarsaune (Sun Nov 01, 2020 6:26 am) • wbergman (Sat Oct 31, 2020 7:38 pm)
PostPosted: Sat Oct 31, 2020 5:00 pm
Still though it's best to think of two pieces of wood are held together by a molecular rather then a mechanical process.
These users thanked the author jfmckenna for the post: wbergman (Sat Oct 31, 2020 7:38 pm)
PostPosted: Sat Oct 31, 2020 5:25 pm
glues is usually about a .007 in layer between the 2 pieces. If the glue flexed it would dampen the movement. That is why the animal protein glues are so good also they are not prone to cold creep like tite bond.
so a little glue 101
A there is drying glue such as the hide and fish glue
this means that they can reamalgamate and become glue again when steamed , so the glue will stick to itself
B Curing Glue
tite bond is a prime example of curing glue , once cured it never will become glue again
This means that once the curing process is over your glue will not stick to itself and you will need to remove the old
glue when regluing a joint
C chemical glues
epoxy is a prime example
Mix 2 parts the material goes through a chemical reaction and usually heat is involved
These users thanked the author bluescreek for the post: wbergman (Sat Oct 31, 2020 7:38 pm)
PostPosted: Sun Nov 01, 2020 11:51 am
'Modern' cold glues, such as Elmer's and Titebond, tend to suffer from 'cold creep' which you don't get with traditional glues such as hide glue. I have seen thick glue lines with the modern glues, particularly Elmer's, that have shifted noticeably in shear. In one case a bridge on an import guitar had shifted toward the neck by about a mm, with a line of bare wood along the back edge and a ridge of finish in front. I saw a neck on an American made guitar that had shifted inward by about the same amount. The glue line between the UTB and popsickle stick braces had not broken, but the wood had moved. The inside of the top looked like it had been smoothed with very coarse paper, which left a thick glue line: they might as well have used a garden rake.
Hans Mattes wrote:
"That's quite demanding and is why significant clamping is necessary to distort the wood surfaces into such intimacy."
You should not need to 'distort' the surfaces to get good glue lines. Clamping is the usual way of squeezing out excess glue, but if the surfaces fit properly other methods work well. Violin makers traditionally make 'rub joints' for the center joins of tops and backs. Once the surfaces have been planed level one side is clamped in a vice to hold it, with the glue side up. Hide glue is spread on both surfaces, and the two are rubbed together with firm pressure to force out excess glue. When the glue starts to 'grab', but before it gels, you slide the two pieces into alignment and walk away. If they have been properly planed the glue line will be virtually invisible, and will hold up well. I'd say that proper work calls for well fitted surfaces and careful clamping that avoids distortion.
These users thanked the author Alan Carruth for the post: wbergman (Sun Nov 01, 2020 4:18 pm)
PostPosted: Sun Nov 01, 2020 1:00 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Does anyone know if 'cold creep' is a feature of the adhesive or a byproduct of poor gluing technique? And if so, which techniques may allow cold creep?
Thanks!
Peter Havriluk
These users thanked the author phavriluk for the post: wbergman (Sun Nov 01, 2020 4:18 pm)
PostPosted: Sun Nov 01, 2020 3:58 pm
Creep is a property of plastic, therefore it's inherent to plastic based glues. I'm sure different formulas have differing amounts of creep. A good quality glue joint probably helps minimize it though. There's been millions of guitars built with Titebond and by far the majority of them don't seem to be suffering from creep issues.
If you want to eliminate creep you probably need to move to hide glue.
These users thanked the author Jim Watts for the post: wbergman (Sun Nov 01, 2020 4:18 pm)
PostPosted: Mon Nov 02, 2020 3:02 pm
"If you want to eliminate creep you probably need to move to hide glue."
That's been my experience.
It's plausible that the mechanisms that cause cold creep contribute to damping, but it would be very hard to isolate that well enough to be sure. Whatever sort of glue you use, good design and construction practices that produce minimum glue line thicknesses help.
These users thanked the author Alan Carruth for the post: wbergman (Mon Nov 02, 2020 6:26 pm)
PostPosted: Mon Nov 02, 2020 4:13 pm
Most cold creep is the glue itself . The better your joint stronger the glue bond. Like Al Hot hide and fish are the best for not having clod creep.
These users thanked the author bluescreek for the post: wbergman (Mon Nov 02, 2020 6:27 pm)
PostPosted: Mon Nov 02, 2020 7:20 pm
I've been using HHG and Lee Valley 2002 glue. The 2002 glue has a high solids content (45%). It appears to have some of the same qualities as protein glues. When I didn't get to the squeeze-out until after it dried, it chipped off clean and felt 'glass hard'. Only real downside I see is the brownish color when it dries, so I only use it on darker woods or unseen joints. I can't see that there would be any cold creep with it.
Brent
Users browsing this forum: DennisK and 13 guests
